Arcam AVR support?
jgus's Avatar Topic Author
Arcam AVR support?
#2473
I was disappointed to discover there didn't appear to be a driver for Arcam AVRs (specifically I have an AV41.)
The protocol is publicly documented at www.google.com/url?sa=t&source=web&rct=j...lYn6P4PmrIaYuOwTPAOv
Home Assistant has a robust integration, with source at  github.com/home-assistant/core/tree/dev/...components/arcam_fmj
Any chance of getting a driver for these devices?
Re: Arcam AVR support?
#2516
It's practically impossible to have drivers for all devices. it only makes sense to do them when there is an established need. To that end, an Arcam driver has just be released. Standard caveats in play. If I followed the protocol doc correctly it should discover the amps and you will have basic control. Nearly all the api commands are supported including the simulated IR commands. This should provide all the control that is needed.
I have no way of testing the driver locally. If there are issues I'll need to see the verbose event logs and, ideally, remote into your controller for troubleshooting.
Time to create page: 0.060 seconds
