Shelly devices not discovered/no way to manually add
glc650's Avatar Topic Author
Re: Shelly devices not discovered/no way to manually add
#750
What does this line mean/how do I do this?
Enable MQTT server on myServer in Command Builder port 1883
#751
check out the Doc again
allonis.com/support/documentation?view=category&id=420
Use myServer Command Builder (click on "Wizard Hat", then the "Hammer")
#756
Also I was also only able to test a handful of Shelly devices. I may have to scan your Shelly devices to make sure they get supported.
#771
I have the same issue.  I have a Shelly Plus1 add-on with 5 temp sensors attached to it.  I can access it via its web address 192.168.1.109 with my phone or my PC.  I can switch its relay on/off from my phone.  I checked the settings just now after referencing the updated documents above, but Myserver6 still will not find it when I hit the "Discover" button.  A few weeks ago it successfully found two Shelly Plugs that I added to control a fan and a dehumidifier in my theatre room and I've been using those in my theatre room automation ever since.
#787
I still can't get it working after enabling the MQTT server on myServer:
drive.google.com/file/d/1Qlif8XFm3aT3HhF...WqF/view?usp=sharing
And setting up MQTT on the Shelly device:
drive.google.com/file/d/19nU19AYQKpe5pux...V9N/view?usp=sharing
Last edit: 2 years 7 months ago by glc650.
#796
I will be looking at Shelly tomorrow. Will post when I have an update.
