Shelly devices not discovered/no way to manually add
glc650's Avatar Topic Author
2 years 9 months ago
#738
The Shelly driver doesn't discover any of my Shelly devices and when I click on Driver Command Testing there's no option to add a device.
Re: Shelly devices not discovered/no way to manually add
#741
Are you using a standard Allonis provided myServer controller?
We haven't seen any issues with this if it's setup properly according to the documentation.
If you have a firewall / antivirus / VM / Proxmox etc then that's where the issue is.
#742
Yes.
#744
I'm using an RPi purchased (and preloaded w/myServer) through Allonis same time I purchased the SmartRemote.
#747
Using the search in the documentation didn't find it for me. I had to manually look through all of the directories. In case anyone has problems finding it here is the link
allonis.com/support/documentation?view=category&id=420
#749
Time to create page: 0.099 seconds
