myServer 6.8 on 32 bit systems
1 year 5 months ago
#4350
Allonis continues to add new features and uses the latest software to do so.  Effective with today's myServer update, 32bit operating systems are no longer supported as key dependency files only exist in 64 bit operating systems.
All SmartRemote systems should all be 64 bit generation so nothing to worry about.
If you do by chance have a 32 bit system (like "Bullseye" OS), you will need to upgrade to the latest Master Image (64 bit) and move your myServer specific files (typically wwwroot and the myServer database).  You can then upgrade to the latest 64 bit myServer software.
You can confirm your OS version by running "neofetch" command from a terminal window.
camens's Avatar
Re: myServer 6.8 on 32 bit systems
1 year 5 months ago
#4351
Thanks for that update David.  Do you guys provide any release notes outlining what's changed or been fixed?
1 year 5 months ago
#4358
No we don't. Way too many updates.
Best strategy is keep all software up to date that you have installed.
Keep backups of your personalized files (wwwroot folders and the database).
