Russoun RNET connection issue
Neilm@comcast.net 's Avatar Topic Author
10 months 2 weeks ago - 10 months 2 weeks ago
#4708
Anyone using this yet?  I was not able to connect via serial, but was able to connect via a Global Cache device.  I am able to use the command power all off and on and the relays click and powers all.  the individual powers are not working.  I don't see any response back from the device.  just got it connected this morning and will continue to play with it.
Last edit: 10 months 2 weeks ago by Neilm@comcast.net .
Re: Russoun RNET connection issue
#4710
I got it connected via /dev/ttyUSB0. the only command that seems to work is the power allon and alloff.. I am also getting rx resonce from the unit
05/01/2026 19:21:12.21 · DEBUG · RussoundRNet.SerialConnect - Controller local connected via /dev/ttyUSB0
05/01/2026 19:21:12.21 · DEBUG · Server.WebCmd - Refreshgrids
05/01/2026 19:21:27.21 · DEBUG · RussoundRNet.TX: (local) - F0 01 00 7F 01 00 70 01 04 02 00 00 07 00 00 7E F7
05/01/2026 19:21:27.21 · DEBUG · RussoundRNet.TX: (local) - F0 01 00 7F 01 01 70 01 04 02 00 01 07 00 00 00 F7
05/01/2026 19:21:27.21 · DEBUG · RussoundRNet.TX: (local) - F0 01 00 7F 01 02 70 01 04 02 00 02 07 00 00 02 F7
05/01/2026 19:21:27.21 · DEBUG · RussoundRNet.TX: (local) - F0 01 00 7F 01 03 70 01 04 02 00 03 07 00 00 04 F7
05/01/2026 19:21:27.21 · DEBUG · RussoundRNet.TX: (local) - F0 01 00 7F 01 04 70 01 04 02 00 04 07 00 00 06 F7
05/01/2026 19:21:27.21 · DEBUG · RussoundRNet.TX: (local) - F0 01 00 7F 01 05 70 01 04 02 00 05 07 00 00 08 F7
05/01/2026 19:21:59.21 · DEBUG · RussoundRNet.RX:RAW - F0 7E 7D 00 00 00 7F 05 02 01 00 02 01 00 F1 37 00 00 00
05/01/2026 19:21:59.21 · DEBUG · RussoundRNet.RX:RAW - 0D 00 00 40 F7
05/01/2026 19:21:59.21 · DEBUG · RussoundRNet.RX: local - Event Message [F0 7E 7D 00 00 00 7F 05 02 01 00 02 01 00 C8 00 00 00 0D 00 00 40 F7]
05/01/2026 19:21:59.21 · DEBUG · RussoundRNet.RX: local - Target Path[1/0] Source Path [1/0]
05/01/2026 19:21:59.21 · DEBUG · RussoundRNet.RX: local - Update Source Selection Event Controller:1 Zone:126 Data=0
05/01/2026 19:22:59.22 · DEBUG · RussoundRNet.RX:RAW - F0 7E 7D 00 00 00 7F 05 02
05/01/2026 19:22:59.22 · DEBUG · RussoundRNet.RX:RAW - 01 00 02 01 00 F1 37 00 00 00 0D 00 00 40 F7
05/01/2026 19:22:59.22 · DEBUG · RussoundRNet.RX: local - Event Message [F0 7E 7D 00 00 00 7F 05 02 01 00 02 01 00 C8 00 00 00 0D 00 00 40 F7]
05/01/2026 19:22:59.22 · DEBUG · RussoundRNet.RX: local - Target Path[1/0] Source Path [1/0]
05/01/2026 19:22:59.22 · DEBUG · RussoundRNet.RX: local - Update Source Selection Event Controller:1 Zone:126 Data=0
Time to create page: 0.085 seconds
