Help with Simple Macro
Chrisan's Avatar Topic Author
3 months 2 weeks ago - 3 months 2 weeks ago
#5086
Trying to create my first macro in MyServer.   It's pretty simple.  If one variable equals something set this other variable to a certain value.   It's not working.
Thanks for any help, Chris
Macro|If|isEqual##{{irrigation_active_zone_1_status}}##on##SetVariable|{{irrigation_active_zone}}~1
and tried this:
Macro|
If|isEqual##{{irrigation_active_zone_1_status}}##on##SetVariable|irrigation_active_zone~1
Last edit: 3 months 2 weeks ago by Chrisan.
Re: Help with Simple Macro
#5087
The overall structure looks correct so I'm not entirely sure where things are going off the rails. What does the myServer log say when you try to run it?
Some off the cuff ideas:
I'm assuming that "irrigation_active_zone_1_status" is a variable that already exists. If not create it. Otherwise, the macro is referencing a server variable that isn't in the database.
I'm not 100% sure if "isEqual" is acceptable syntax. I know some conditions allow for various formatting so it's probably fine but I don't have the documentation handy to verify. I use "IsEQ" and "IsNE" for equal/not equal conditions, so if I was writing this it would look like:
Macro|
If|IsEQ##{{irrigation_active_zone_1_status}}##on##SetVariable|irrigation_active_zone~1!
Note the "irrigation_active_zone" is not in curly braces.
Does your macro contain more than one command and your example is just one command within it? If so also note the exclamation point at the end. This is required at the end of each command within a macro.
#5088
Thanks Nillaz.   That does work.  But I realized what I actually needed was an automation, not a macro.  Another puzzle to crack  lol   Think I figured it out, though.
Chris
