Hi folks,
Been going through attempts to set up my SmartRemote and I feel like I keep hitting walls. Docs links are currently broken, which doesn't help, but even docs I find which might be useful seem quite incomplete once I get to them (latest example: there's a doc page on
MQTT use
which doesn't actually have any details on publishing, subscribing, connecting, or hosting...)
The driver command tester helps a lot for devices supported via drivers, but the macro editor doesn't seem to provide any assistance with authoring anything more advanced than a sequence of commands.
Is there any reference documentation available? Things like:
- a command reference for authoring macros
- an API reference (I see that there's apparently a way to trigger commands... maybe macros too, via API but the only information is indirect like in a brief document on IFTTT or random forum threads. What does that command look like? Is there a command to get and/or set server variables? Trigger automaions? etc)
At risk of making a forum topic that goes in too many directions, I've seen threads suggesting that there are MQTTPublish and MQTTSubscribe commands but I don't know where to learn their syntax and expected parameters - there doesn't appear to be any MQTT-related driver so there's no command tester that will help me discover it. These are the kinds of things that it would be really helpful to have a reference for.
