Extra commands sent
Extra commands sent
Hey, I'm seeing multiple commands getting sent, when I send a generic serial command to my soundbar/AVR.  The issue is, it's causing one press on the remote to raise (or lower) the volume 3 steps instead of just one.  I definitely see it sending twice in the logs, I'm not sure why I'm seeing 3 responses, unless it's just some artifact of receiving multiple requests so fast.
Here's what I'm seeing in the logs:
23/02/2024 16:35:55.35 · DEBUG · Server.doCommand - AV|9~Send~PWSoundbar~Volume Down from dashboard-fx-qvlo
23/02/2024 16:35:55.35 · DEBUG · GenericSerial.doCommand - Cmd=[9~Send~PWSoundbar~Volume Down] Client=[dashboard-fx-qvlo]
23/02/2024 16:35:55.35 · DEBUG · GenericSerial.TX >>> - PWSoundbar:Z1VDN1;
23/02/2024 16:35:55.35 · DEBUG · GenericSerial.RX <<< - PWSoundbar:5A 31 56 4F 4C 2D 33 35 3B
23/02/2024 16:35:55.35 · DEBUG · GenericSerial.RX <<< - PWSoundbar:5A 31 56 4F 4C 2D 33 36 3B 5A 31 56 4F 4C 2D 33 37 3B
Here's what those responses are decoded:
Z1VOL-35;
Z1VOL-36;Z1VOL-37;
Re: Extra commands sent
Did you look in myDesigner at the button you are pressing for the webpage that is loaded of what the actual command / macro is?
#1459
Yeah, it's just calling the serial command directly.  I'm seeing the same thing if I call directly from the Driver Command Testing:
05/03/2024 17:35:57.35 · DEBUG · GenericSerial.doCommand - Cmd=[9~Send~PWSoundbar~Volume Up] Client=[dashboard-fx-posm]
05/03/2024 17:35:57.35 · DEBUG · GenericSerial.TX >>> - PWSoundbar:Z1VUP1;
05/03/2024 17:35:57.35 · DEBUG · GenericSerial.RX <<< - PWSoundbar:5A 31 56 4F 4C 2D 32 35 3B
05/03/2024 17:35:57.35 · DEBUG · GenericSerial.RX <<< - PWSoundbar:5A 31 56 4F 4C 2D 32 34 3B 5A 31 56 4F 4C 2D 32 33 3B
The VolumeUp and VolumeDown macros are programmed to send 3 volume steps per press.
If it's the macros causing the problem you can edit them and remove the trailing ~3 on the command.
AV|{{livingroom_avamp_id}}~Volume~Down~3!
becomes
AV|{{livingroom_avamp_id}}~Volume~Down!
etc...
I doublechecked, I've got the volume up/down buttons defined as:
volumeup.{{activeroom_{{clientname}}}}
Looking at the macro, volumeup.livingroom, it's defined as:
Macro|
// The macro is responsible for controlling volume in a room!
AV|9~Send~PWSoundbar~Volume Up!
Also I'm seeing the same behavior with every command, even from the Driver Command Test page
Time to create page: 0.115 seconds
