Trouble adding cameras
Will Riker's Avatar Topic Author
1 year 8 months ago
#4115
Once the cameras have been added via webrtc, what is the next step to add them to the server?
Re: Trouble adding cameras
1 year 8 months ago
#4116
1 year 8 months ago
#4120
I'm trying to use the IPCameras driver.  That link refers to the media matrix driver.  Is the IPCameras driver no longer supported?
1 year 8 months ago
#4124
allonis.com/support/documentation?view=category&id=223
If that doesn't work, be specific on what you have done, and what you are seeing in logs / error messages. Also make / model of the IPcamera.
Ultimately, the MediaMTX driver will supersede the IP Camera driver as it has much more transcoding capability. But documentation isn't as available yet to do so.
1 year 8 months ago
#4125
IPCamera driver is fully supported. If you are only working with IP Cameras then it is the way to go. The MediaMatrix driver has many other capabilities and it is primarily used in our commercial jobs.
I looked at your server and saw the you had not yet added the RTSPtoWeb host in the driver. I added the host. Then I noticed that you already had two cameras defined. So I went back to the driver and ran the RTSPtoWebSync command. This brought in the two cameras you had defined and created video_2 and video_3 devices,
From your tablet project you will now see these two cameras.
1 year 8 months ago
#4132
Ah ok, I was unclear about the check box for enabling a local RTSP to web host.  I thought perhaps that when that box was checked, you didn't need to still add it.  I also wasn't aware of the sync command.
Those 2 cameras were still defined from the first setup but they weren't working after I restored the database to the new USB drive,
Thanks!
