IR or Ethernet?
IR or Ethernet?
2 years 9 months ago
#105
I'm a future Remote user. I have an LG WebOS TV (C1) but don't have it disconnected from wifi/ethernet. I currently control it via IR. I obviously don't use it's apps but simply turn it on/off and change inputs. Is there any benefit to turning wifi back on the TV and controlling it via IP vs IR for the little I do?
billd's Avatar
Re: IR or Ethernet?
#112
IR is a one way communication. When using IR the controller has the possibility to be out of sync with the true state of the TV if the TV is controlled by a different remote or control system. Serial may be an alternative if you want 2 way communication without IP connectivity.
Re: IR or Ethernet?
#121
As a general statement, you should always use IP (ethernet or second choice Wifi) and not use IR.
But IR has tremendous device coverage. LG TVs should be IP for sure.
Re: IR or Ethernet?
#126
Thanks, I turned off the TV's internet so that A) It wasn't spying on me and B) Wasn't bothering me about updates. I'll consider turning it back on.
Re: IR or Ethernet?
#128
you can turn off software updates. That's not turning Internet off. See the documentation for LG TVs on setup.
