Shelly Driver Updated
davep's Avatar Topic Author
The Shelly driver was updated today. I've been able to test it with Shelly plugs, a Humidity and Temp sensor and a Shelly button.
The driver is picking up all the properties being broadcast from these devices. I do not have any Shelly dimmers so the driver will be lacking in dimmer support.
If you have Shelly dimmers, or your devices are not being automatically discovered you can advance the development of this driver by turning on verbose event logging in the driver and let it letting it run for a day or for a long enough period of time where there is sufficient Shelly traffic in the log. Then email your server log to me so I can post process the traffic.
Re: Shelly Driver Updated
Thanks Dave.  That is awesome.  I tested it with my system and the ShellyPlus is now recognized but not the Add-on.  I don't see any temperature sensors.  There are 5 temp sensors attached to my ShellyPlus
Also, Myserver6 cannot find my ShellyPlusHT heat and Humidity sensor.  I think this may be my setup of the device so I am playing with that.
I turned on logging so hopefully I'll have some data for you soon.
Thanks,
Graydon
OK I fixed the ShellyHT sensor so that it is now discovered and recognized by Myserver6.  The weird thing is that it can not be accessed from its IP address unless I put it in Setup mode via the little button inside.  The other Shelly devices can all be accessed via their respective IP addresses.
Secondly Myserver6 is still not finding the Add-on on top of the ShellyPlus1 so I can't read the temp sensors.  The Add-on does not have its own IP address.  It piggybacks on the ShellyPlus1.
That's why I need to see the Verbose Shelly logs. Shelly has wonderful api documentation but the one thing they are lacking is documenting what the mqtt traffic is from their devices. So I dump all the traffic into the logs so I can I can parse them to see what I need to add.
Verbose logging is turned on if you want to log in and take a look
#1214
I deleted the ShellyPlus1 device in the Shelly driver thinking that maybe we could re-discover it and maybe it would discover it correctly.  Well, that didn't work.  Now it won't discover the ShellyPlus1 at all.
UPDATE:  Today the ShellyPlus1 showed up in the Shelly driver list of devices.  It still doe snot have the Shelly Add-On with its five temperature sensors however.
Last edit: 2 years 8 months ago by graydon@gdsamps.com.
