Marantz AV10
Marantz AV10
10 months 3 weeks ago
#4688
I have a Marantz AV10 Processor.  I assume I should use the Marantz AVR driver, but my processor is not listed in the Receiver Model drop-down.
Other than just randomly trying each one, is there a model choice that will allow me to control the AV10?  Or do I need to wait for a new driver?
PhoenixF15E's Avatar
Re: Marantz AV10
#4690
I also have the AV10.  I think I used the 7007 receiver from the dropdown, but I don't think it really matters.  Not much has changed with Marantz/Denon IP control over the years.
I did need to use a few custom command since I added aux inputs via some button pushes on the front display.  The ~test~COMMAND feature comes in handy to do anything that isn't included in the integration.  This is my command to select the AUX4 input:
AV|30~test~SIAUX4!
The test command can be used to do any IP command you need.  Denon does a much better job publishing their control protocol.  I've attached a copy.  If you need a command that isn't in the integration, just use the test command and put in the correct string like I showed above.
The following user(s) said Thank You: cjisble
Time to create page: 0.061 seconds
