Dune HD Players?
Dune HD Players?
4 months 3 days ago
#5023
Is there any plan for a Network driver for Dune Media Players?
dune-hd.com/support/ip_control/
There is an IR "In" port, so worse case I could use the Global Cache IR codes.
Thanks!
Re: Dune HD Players?
4 months 2 days ago
#5024
from very distant memory...I think there was a driver back in the day....
4 months 1 day ago
#5025
In the absence of a driver you could just call the API directly in your buttons/macros.  I've done that with a few different devices that didn't have a driver.  To make it easier you can create macros and then just pass in the parameters that are different and have the macro build the http request.
4 months 1 day ago
#5026
For IP control I think I'm going to use Home Assistant.
www.home-assistant.io/integrations/dunehd/
I may use the model I use with ATV and have both IP and IR control and the config is triggered by a variable (use IR or IP).
On a side note, the Dune Duo 8k Cinema device is interesting in that it has a certified (Netflix, Google, etc) board built in along with their proprietary 8K board. This would allow me to get rid of the Roku and possibly the ATV.
Time to create page: 0.066 seconds
