2 problems
2 problems
2 years 1 month ago
#3385
i I've finally gotten round to setting up the Moonlight template on my phone and it pretty much worked out of the box. I just have 2 issues:-
1) My cable tv had to be setup as an IR device. Using my phone I can power on & off, change volume and switch activities. Apple TV works fine, Shield works ok but is part of my 2nd problem. What I can't do is control my Cable TV. Strangely the Menu button works. It is set up as AV|134~Remote~MENU MAIN as a server command in myDesigner. I have copied this into the other buttons, making sure I am using the correct command from the IR Database.but I can't get it to work. Looking at the logs it looks to my inexperienced eyes that the Generic IR driver isn't triggering the Remote command (the Menu button does)
2) My Shield appears not to have a Dpad so I can't move my cursor. i've swiped in case  it was hidden on another page
Any help would be appreciated
Time to create page: 0.064 seconds
