iPad resolution help!
2 years 1 month ago
#3359
Hi Guys,
I'm using an iPad Air 2 with myServer.  The (very basic) design/ setup is largely my own - not using the moonlight one.
I get a strange jump/ glitch in the (Allonis blur) background image when changing between pages.
I'm certain this will be due to the resolution being wrong, and scaling going on - and I'd love to fix this once and for all.
The iPad Air 2 has a resolution spec of 1536 x 2048 - but iPad OS takes up some of the screen with the bar at the top.
I'm hoping this isn't a silly question...  Feeling like an idiot here - but am sure this is the root of the problem...
What settings should I use for the myDesigner project properties - custom properties section - for this spec of iPad?
(page width/ page height/ scale factors/ scaling)  I'd also like to show as much of the cool "blur" image as possible rather than just a corner of it.
Apologies if there is guidance on this somewhere that I've missed...!
Cheers
Ben
Re: iPad resolution help!
2 years 1 month ago
#3367
Hi Ben,
Copy all settings from Moonlight Tablet.
I would start with that and customize from there.
Starting from scratch puts you into la la land.
#3374
Thanks David.
Tried resetting to the Moonlight settings - but that resulted in my setup being twice the size of my screen...
I can't now set it back - changing the settings back to my previous project resolution (2048x1536) seems to save in myDesigner - but doesn't change what I'm seeing on the tablet (despite refreshing and restarting everything...
Any ideas how to set this back - think I may need some help!
Sorry...!
Last edit: 2 years 1 month ago by allonis@bendavies.eu.
#3378
Really stuck here guys.
Following the advised reset of settings - even launching the remote from myDesigner only shows the top left hand part of the screen.
Resetting the project resolution has not restored it.
Any help gratefully received.
#3379
Figured it out!
Somehow I'd not ticked "enable app scaling" and "enable desktop scaling" when reverting (I was convinced I had...) - these made the "launch" remote work again from designer.
The web page shortcut on my iPad was still not working properly despite restarting everything, clearing cache etc - so I deleted and recreated the home page shortcut - and it all works again!
So just back to the original problem. I'll perhaps try creating a version of the "blur" background in the exact ipad resolution next - to see if that stops the background jumping on every pageload.
