myServer Controller Customizations
Sat32's Avatar Topic Author
2 years 2 months ago
#3165
What about upgrading to pi 5, I know storage speed makes a big performance difference with MyServer since the pi 5 has PCI-e and a NVME drive can be added. Would that and the increased cpu power be worth it.
Anyone here on the forum using pi5 with experience with running myserver on pi4
Re: myServer Controller Customizations
#3166
A Pi5 with a nvme is nice because it boots fast. But no real difference in use.
Some of our video features require a Pi5 / OrangePi5Plus (the MediaMatrix driver). But if you aren't using that, so real need for a Pi5.
#3172
FYI I'm guessing my Pi 4 died because of a overheating issue, MyServer seems more demanding then Home Assistant. The case I was using ran HA for years but with my server it was really hot to the touch. Since Was getting a new case with better cooling I wanted to add a M.2 drive as well. Between the board and the case it was only 10 dollars more for the Pi5 and significantly faster.
PI 5 8gb
Argon NEO M.2 Case
Crucial p3 plus 500gb
Argon Pi 5 power supply
#3173
You should look into our new Modular case and put both HomeAssistant Pi and myServer Pi 4/5 in same nice rack or shelf mounted case.
myServer uses a trivial amount of cpu on a regular basis. Similar to HomeAssistant.
#3174
That would be nice to have all my stuff in a dedicated server rack, someday maybe. Right Now I have a wire utility shelf with all my stuff on it.
#3175
Note that the modular case doesn't require rack ears and transforms into a shelf mount AV device :)
Time to create page: 0.090 seconds
