Internet connection drops every night
#1711
My myServer loses it's internet connection every night.  A reboot restores it.  It is sitting behind a Firewalla Gold Firewall and I tried turning off all firewall rules for that device to see if it made a difference.  It did not.  Any suggestions?  None of my other devices have this issue (5+ PI's, 100+ IOT devices, etc.).
Re: Internet connection drops every night
#1716
Not enough information here.
Provide your TeamViewer ID so we can look.
#1718
Here you go.... 1621798135
#1726
Hi,
I see that Weather sometimes struggles to get Internet access. Other than that, no sign of issue in the log.
I also see that various network files have been modified since Allonis created this Master Image. Teamviewer too. So, the networking baseline is now not standard.
There are no other systems we have built that exhibits the same behavior.
I would suggest for support, that you backup the system, restore to the original Master Image and then update the new system with Allonis updates, and bring the system back to your backed up system config. Otherwise this can take many hours to figure out (not covered under warranty) and include you sending your system back to Allonis.
It also seems that you have an IPV6 network setup. I would unbind IPV6 from myServer as that isn't needed. who knows, myServer might be getting confused with the IPV6 network. I would do that for you, but don't want to screw it up and then can't do anything remotely.
I will let DaveP know of this situation to see if he has further thoughts on it.
#1727
I have not touched anything in the network section.  This server is as provided by Allonis.  The only thing I have done is Reboot it when the dashboard shows Internet Offline.  I've updated the software via the updater, and added Drivers and now some Macros.
#1728
My system is new....I just received it last Wednesday.
