Internet connection drops every night
Re: Internet connection drops every night
#1739
I figured out the macro syntax after playing around a bit.  I have a few system macros that are now working.  There were a lot of commands missing in the Anthem driver (vs the IR driver).  For example, cursor commands.  If I can use the network one I will.  My goal is to get the system functional first, then work on the aesthetics.
I haven't had a chance to test this yet, but I believe the commands you are looking for in the Anthem driver can be sent using the IRCmd command.
#1775
Update - It's been two nights and the connection has not dropped.  It looks like whatever you did fixed the issue.  I'm not sure if it was just disabling IPV6 or a combination of things.
#1791
Awesome to hear!!
I bet it was the IPV6 deletion.
Your higher end router supports IPV6, it might not be properly configured and that was confusing the myServer controller's networking.
It was suspect when I did a "ifconfig" on your system and saw how many IPV6 connections there were.
Glad to hear it looks resolved as that one could have been a bear to find otherwise.
Time to create page: 0.318 seconds
