Internet connection drops every night
Re: Internet connection drops every night
#1729
Is the SmartRemote on the network? Can't find it in the AndroidTV driver. Then can't Inspect it
#1730
I have not accessed anything on the server directly, it has all been through the dashboard. If any of the network files have been changed, it is via your software. I look at the network settings (via the dashboard) but didn't change anything.
#1731
No, the SmartRemotes are not setup yet. I'm working on the software config first and once I have a system working, I will add the SmartRemote. I've tested the drivers via the server and the mydesigner software.
#1732
I added the "smartremote" folder (copied that from the latest smartremote-sample).
So when you setup your Smartremote, use the standard "smartremote" folder name.
I did a full backup of the system for you.
BTW, I might have confused two windows on my PC...I was looking at a development box we are working on here and not yours ;)
Just a tab away :)
I will have Dave take a look to see if he has any ideas.
David
#1734
Ok, took another look.
We disabled IPv6 as that might be causing myServer confusion on your network looking for an Internet IPV6 connection that doesn't exist.
We also see you are trying to concantonate commands together using Linux &&. You should look at the myServer Macro Command structure for how it needs to be done.
We see you are using IR for your Anthem - there is now an IP driver that likely will be better.
We are restarting to see if the IPV6 deletion addresses the issue of network. Let us know!
#1738
I figured out the macro syntax after playing around a bit.  I have a few system macros that are now working.  There were a lot of commands missing in the Anthem driver (vs the IR driver).  For example, cursor commands.  If I can use the network one I will.  My goal is to get the system functional first, then work on the aesthetics.
