Oppo IO Driver Issue
Re: Oppo IO Driver Issue
#1989
We're close!  The preceding "#" and trailing space are now in the command.
The command needs to be terminated by ASCII 0D (CR) followed by ASCII 0A (LF).  What's actually being sent is the ASCII of the shorthand characters "/r/n" (2F 72 2F 6E), not 0D 0A.
I attached the MyServer log and WireShark capture below
Last edit: 2 years 6 months ago by PhoenixF15E. Reason: Added text to mention the logs are attached.
#2000
I'm forever typing /r/n when I know it is supposed to be \r\n.  Usually I catch it. Driver is updated.
#2037
Thanks!  My limited testing shows everything working as it should.
retate's Avatar
#2167
Based on limited testing control of the Oppo UDP-20x players is working. However, the Oppo BDP-103 is not working. I was able to get connected to the BDP-103 (based on log messages) by changing the control port from 23 to 48360, but test commands do not seem to do anything. I have not had time to analyze why control of the 9x/10x players is not working. I have attached the Oppo control protocol document for the 9x/10x players if someone has time to dig into this further.
#2187
Yes completely different protocol. retate - What IP address is your Oppo at? I'd like to remote in and test some commands.
retate's Avatar
#2193
Oppo BDP-103 - 172.16.1.64
Oppo BDP-203 - 172.16.1.74
Oppo UDP-205 - 172.16.1.54
Teamviewer ID sent via email.
