Oppo IO Driver Issue
#1885
I had a chance to test drive the new Oppo driver and try out a few commands.  Unfortunately none of the commands worked.  The verbose MyServer log showed the proper command being sent.
I fired up Wireshark on MyServer and it saw MyServer was sending a message to the Oppo with the proper command but it was missing the proper formatting.  Here is the syntax for passing commands according to Oppo:
<Command> = <Start of Command><Command Code>[<sp><Parameters>]<End of Command>
<Start of Command> = #, ASCII 0x23
<Command Code> = <byte><byte><byte>
<sp> = space, ASCII 0x20
<Parameters> = command-specific
<End of Command> = CR, ASCII 0x0d LF, ASCII 0x0a
Moving the cursor right should be "#NRT<SP><CR><LF>" but all I see on several attempts is "NRT/r/n" which doesn't work.  The query for power state right after the NRT command has the same incorrect format.
It looks like there are a few commands that support parameters, but hopefully more can be added later to give direct access to things like subtitle shift, Zoom (SZM), etc.
I didn't test all of the commands, but Zoom doesn't seem to transmit after correctly parsing the command.
I sent the command "#NRT<SP><CR><LF>" to Port 23 on the Oppo and it worked as expected.
Re: Oppo IO Driver Issue
#1886
I've attached the Oppo protocol below.  For some reason I couldn't add an attachment to the first post in a new topic.
#1904
The oppo was supported in prior myServer versions so must have been an issue on the port to myServer6.  Your logs will likely help resolve.
#1923
I've attached a Zip file with a MyServer log and an associated WireShark capture with traffic going/coming from my Oppo 203 during the same period as the MyServer log.
I tried sending the Zoom command twice from the dashboard but it isn't sent.  The other commands I tried from my SmartRemote also work from the dashboard; for some reason Zoom is different.
Mark Guebert's Avatar
#1961
I am also having problems with my Oppo 203, none of the commands work, however the logs indicate the commands are being sent successfully.
#1984
Oppo driver has been updated. Thanks for finding and reporting that.
Time to create page: 0.097 seconds
