Refresh Rooms
camens's Avatar Topic Author
Refresh Rooms
#4295
I've added another Apple TV device to the 'Whole House' room, but it is not showing up in the 'Sources & Apps by Room'.  Is there a way to refresh the system after adding something to a room?
Link to Image
Last edit: 1 year 6 months ago by camens.
Re: Refresh Rooms
1 year 6 months ago
#4306
Not sure how things got there...you can try to delete the device (associated macros myServer should then auto delete) and readd it. Try a unique name while adding it. Try not to edit the name after it is initialized.
You can also manually inspect the macros for the device.
You could also manually create the device macro.
But there isn't a "refresh" as this system is dynamic and doesn't need a refresh.
The Room associated macro must be manually edited to add a device as Active when that room is selected. And any settings associated to that device (like an audio matrix has many sources and several Zones (rooms) that might apply to that room).
Time to create page: 0.062 seconds
