Error Flood
Error Flood
3 months 2 weeks ago
#5085
I'm getting flooded with this message.....I'm pretty sure it happened after the last myServer update.
04/08/2026 00:02:53.02 · DEBUG · Server.doCommand -
"BackgroundMacro|SetVariable|smartremote_battery_{{clientname}}~98!SetVariable|smartremote_charging_{{clientname}}~true" from remote0
04/08/2026 00:02:53.02 · DEBUG · Server.doCommand - "BackgroundMacro|SetVariable|smartremote_battery_remote0~98!SetVariable|smartremote_charging_remote0~true"
04/08/2026 00:02:53.02 · WARN · Server.doCommand - Unknown command
04/08/2026 00:03:28.03 · DEBUG · Server.doCommand -
"BackgroundMacro|SetVariable|smartremote_battery_{{clientname}}~21!SetVariable|smartremote_charging_{{clientname}}~true" from remote2
It just repeats and repeats...
Re: Error Flood
#5089
Any update.... This is not a user created command or macro, it's a system issue "Unknown Command".
Re: Error Flood
#5090
I'm not seeing these errors.  However, on my remote, the charging indicator is always lit, even after I take the remote off the charger.  I wonder if they are related.
Re: Error Flood
#5091
I'm also seeing a similar behavior on the remote. My one remote has the battery level displaying around 50% and it doesn't change. I have also seen the Charging icon not showing up when the remote is in the base.
Something changed.....
Re: Error Flood
#5092
Today's server release fixes the issue. Thanks for finding it.
The following user(s) said Thank You: cjisble, bitzerjd
