Need some clarity/guidance
Re: Need some clarity/guidance
#1277
from newer documentation
Backing up the myServer system
Now that you have done some configuration, best to do a backup of the myServer 6 system
Backup the template(s): Create a wwwroot\backups folder. Copy the "smartremote" folder into backups. Download from software updater the "smartremote-sample". Rename that "smartremote" in the wwwroot folder. You are then using the latest files from Allonis. If you had a custom "mywebpage.html", you can copy that from backups\smartremote into the wwwroot\smartremote folder.
Do you want me to TV into your system to see what's up?
I upgraded to the latest smartremote-sample.  You old ones are in the backups directory.  All seems to be fine...what is the issue?
We used to start at an index page of all devices(a week or so ago). If this new layout is the default going forward that's fine, I just wanted to know if there was indeed a change made or if I wrecked something . Honestly I like the current layout better than the previous as it's one menu level less now.
I did the updates 5 minutes before I invited you in. So all should've been up to date.
#1279
well, there was an outstanding template update that was available so I implemented that for you. But I haven't moved any custom webpages stuff into the active template ("smartremote").
This is the latest and greatest
You might have seen "all devices" because you hadn't set your ActiveRoom at that time.  Now that you have selected an ActiveRoom, those settings persist (in variables) even if you change the template.  That's what drives what icons are on the page..
#1280
Okey dokey. Thank you for the clarification.
Time to create page: 0.429 seconds
