Automation to turn the SmartRemote screen off when charging
Re: Automation to turn the SmartRemote screen off when charging
#1725
What's the specific issue with the AndroidTV driver?
And please post issues in their respective forums so it doesn't get lost.
Sat32's Avatar
#1735
No specific issue, but having equal access some of the information HA debug driver provides would allow a lot of options to configure, current app, image of whats on the screen.
And I was sorting messing around with a way to have a inactivity automation so instead of dimming the remote screen show a black image or dimmed clock. That's why I connected the HA android debug to the smart remote. Like the turning off the screen while charging automation that this thread is about.
I asked about a variable for the remotes accelerometer a while ago and was told it would flood the server with information slowing every thing down. That made sense but could it be done in a way that would only update after a state change.
ie no motion for a while screen dims = varible smartremote~sleeping
first motion after sleep state = varible smartremote~awake
just a thought
stanger89's Avatar
#1763
Perhaps a dumb question, but does this require setting up the AndroidTV driver?  I was trying to figure out the AV ID of my smartremote and not finding it anywhere, but slowing absorbing the thread it sounds like that's because I don't have the AndroidTV driver setup so the remote isn't found as an AV device?  If so, is there another way to sleep the remote without the AndroidTV driver?
#1764
Yes, Requires AndroidTVDriver.
And Discover your turned on and networked SmartRemote.
Takes a few minutes but it should find it.
Then myServer can do things like turn the screen off.
stanger89's Avatar
#1765
Yup, got it working.  I ran into the same issue as CrabbyPatties a couple of times in the process.  Restarting myServer fixed it each time, we'll see if it keeps working.
Last edit: 2 years 6 months ago by stanger89.
The following user(s) said Thank You: CrabbyPatties
CrabbyPatties's Avatar
#1768
Yup, got it working.  I ran into the same issue as CrabbyPanties a couple of times in the process.  Restarting myServer fixed it each time, we'll see if it keeps working.
It's 'Patties'.  As in SpongeBob.  As in being a parent has finally driven me a little insane.  'Panties' is a bit too weird, even for me.
Time to create page: 0.502 seconds
