Automation to turn the SmartRemote screen off when charging
bitzerjd's Avatar
Re: Automation to turn the SmartRemote screen off when charging
#1782
Holly Crap it worked! Got rid of the <> and added WHEN:
Thanks!!!!!
#1787
Yup, the forum software isn't the best (probably more the configuration of it).
This is (again), part of the "Kickstarter" work to be done.
Allonis hasn't really needed a forum (or even a good website or documentation) for our commercial business which is still 90% of our work.
It's on the list to investigate and improve.
You can Quote someone and that brings in their comments into your edit panel.
#1788
Interesting...I never knew that either....
Thanx for the find!
#1789
Hmmmm,
I cannot get this to work.  I can send a command via AndroidTV to the device (I just turned off the power).  The device is named remote0  and it's ID is 14
The two commands are like this:
{{smartremote_charging_<remote0>}} = true
Macro|
AV|14~SendKey~SLEEP!
It seems the conditions are never met...so nothing in the log.
Should you be having <> around "remote0"?
No, there should not be <> around remote0 unless that truly is the name of the variable in myServer's list of variables (check there).  << >> are used by "programmers" to indicate a placeholder of stuff (like a variable name that might be different on your system).
#1790
Thanks!!!!!
Cool!
You are opening the door for extreme customization and capability with this stuff....it will start to get way more fun now that you are seeing the myServer fundamentals of commands.
Time to create page: 0.353 seconds
