Function Keys
Function Keys
#1831
Is there a trick in using the Function Keys (F1...)?  I've put in a valid command and it doesn't register on the server.  It's the same code that's in a button so I know the code works.  I simply want the F2 command to turn on a light (short press) and off (long press).
Re: Function Keys
#1832
What is the command you have assigned to F2?
Re: Function Keys
#1833
I tried two codes:
Macro|chair lamp on
and
Lighting|48~On
When I press the button, nothing is recorded on the server. Both commands work fine on other buttons.
Re: Function Keys
#1834
Hmm. Is the soft button that works in the same scene as the hard button you assigned the command to?
Re: Function Keys
#1835
No, I simply want to control the Home Theater lights by these three buttons. The commands work on other hard buttons, just not these. No errors on the server, the command is not being sent.
Re: Function Keys
#1837
Gotcha. I thought maybe you had assigned the commands to a specific scene instead of globally in Project Properites. If it works on some keys but not others within the same scene I'm totally at a loss.
Time to create page: 0.342 seconds
