Function Keys
Re: Function Keys
#1862
I'm not the expert but it looks like you're trying to run a command then tack a macro string of commands on after that. I think you need the macro command as the first thing in order to run a string of commands separated by '!' characters. So it should be:
macro|fam1|cmd1~arg1!fam2|cmd2~arg2!fam3|cmd3~arg3
not:
fam2|cmd2~arg2!macro|fam1|cmd1~arg1!fam3|cmd3~arg3
I think that's the problem anyway.
Last edit: 2 years 6 months ago by andrew.
Re: Function Keys
#1863
That worked. Thanks! I thought the ! was the separator for individual commands so order wouldn't matter.
Re: Function Keys
#1864
I think the only way you can have a string of commands separated by '!' characters is to use 'macro|' at the beginning of the line - that's what it's for.
Re: Function Keys
#1866
I moved the logic back to server macros. This way on the remote it's a simple trigger.."Macro|tivo" for example. I also like the line by line list in the server Macro Editor, it's easier for me to see it on the laptop vs the line in Designer.
Re: Function Keys
#1867
Back to the Original Issue...Sorry for the side track.  Long Press on the "Home" button doesn't work for me.  It's a simple command "clientcmd|back"  It works fine on the back button (long press).  Second, nothing executes from the F1..3 buttons (long or short press).  I've tried a client command (clientcmd|back (or home), and it doesn't execute.  I also tried a device command Lighting|48~On and it doesn't work.  The code works if assigned to a regular button.  There is no error in the log because it never gets sent.
Re: Function Keys
#1869
I'll have to remote back into your system to inspect the html on the pages.
Time to create page: 0.466 seconds
