Bueller, Bueller, Bueller
Sat32's Avatar Topic Author
Re: Bueller, Bueller, Bueller
2 years 9 months ago
#324
CodZero are you the same CodOne from the Unfoldedcircle discord?
if so thanks for turning me on to this!
#326
Yes, thank you CodZero / codOne.
And you can imagine what a challenge it is for figuring out who is who....different user names on AVSforum, Discord, Reddit, Facebook, email, Allonis forum, etc....
#331
Hi David Li so far I've been playing around with this thing for like two days trying to wrap my head around how things work and it's not hacked together system at all well polished with incredible depth of options.
Documentation needs work example setting up the HAgateway is all over the place. Should be bold header "under what circumstance follow these directions" then instructions.
Also there is a button under the remote base what does it do?
#332
Hi, Thanx for the positive comments!  yes, HAGateway is all over the place.  That and the Harmony Hub drivers are very new and not tested much.  HAGateway will be even worse because of all the 3rd party stuff on the HA side that doesn't follow any convention.
The button under the base turns the ring light on / off.
#334
I think the entity's added by the HAgateway should be disabled by default, then after there discovered can be enabled one by one. For the stuff you want myserver to interact with
#335
That would have to be done at the HomeAssistant side which today, there is no Allonis code there.  We are using the HA API which provides access to all Devices / Entities.
The licensing "enable" is what we can do on the myServer side.  So, the data will be there, but not enabled and therefore not doing anything on the myServer side.  With next UI changes, you should be able to sort / filter this stuff so you are only interacting with what you have chosen to be of interest.
Time to create page: 0.090 seconds
