Adding additional JVC projector commands
8 months 2 weeks ago
#4805
Hi,  I am back at setting up my SmartRemote after some time off.  I have most of my devices set up but the JVC Driver that I tried for my DLA_NX7 is pretty limited as far as handling the projector commands.  I don't see any easy way to add commands to this driver.  With that said I'm looking for another way that I could start from scratch using a generic driver or if someone has another way that a JVC projector can be set up and add more commands to the driver?  Any suggestions or recommendations would be great.
Thank you,  Tom
Re: Adding additional JVC projector commands
#4806
Does your projector have IR (Infrared) capability? My Onkyo AV Receiver is controlled by IP commands, but those available are limited. So I augment those commands with Onkyo IR commands, some of which are "learned". It works great!
#4807
Thanks for the suggestion but all my equipment is behind me at the back of the room.  I do have a HTWeb remote that handles the JVC nicely but i'm not sure how it is doing it under the covers.  I was hoping someone had had success using a serial generic IP driver as I thought it would work but it seems JVC does some things a little different than most TCP equipment or maybe it's me not understanding their commands.  Thank you for the suggestion.
#4809
If you have HTWebRemote setup then why not just send it a URL of the JVC command you want.  I had this setup at one point very early on before a lot of the drivers were really working.  I've since removed that so I don't have the exact syntax but if I remember correctly the URL is pretty straight forward.  If you want to get fancy I created a macro that would take a couple of parameters and then sends the formated URL.
#4810
8 months 2 weeks ago - 8 months 2 weeks ago
#4811
I did try sending the Url commands from the HTweb remote and they sorta worked but then some would give me ConnectAndSend command errors and the JVC would lock up.  I would have to have to unplug it to clear the lock up.
I did set up some JVC commands in the Serial database to try.  If I sent a JVC request command first and then the actual command right after it from the command test area the commands would work.  But if I tried to put the 2 commands (request and actual command) in a macro most times it would do nothing or it would lock up the JVC.   Like all devices, JVC has a their own way of sending and receiving commands and they are always polling for commands according to their  guide:  support.jvc.com/consumer/support/documen...moteControlGuide.pdf .  Maybe I'm missing something in the macro, not sure.   I will try another take at the serial commands later today but I would be interested in the macro you used, it may work in this scenario.  I'm willing to try something new.
Thank you for you suggestions!
Last edit: 8 months 2 weeks ago by Thomas Wheeler. Reason: Wrong error type in reply
