Your SmartRemote settings point to a particular folder name that must match the folder name within the myServer/wwwroot directory. You also could have modified the target folder name on the SmartRemote settings (ie: smartremote-chris"). Recommended is what you did - keep your "production" (in use) folder named "smartremote"....we also make a backups folder and move any out of use template folders into that directory so they don't get read when myServer launches.
Keeping the name consistent (ala smartremote) then also allows you to put shortcuts on other devices to same foldername for ease of access.
Last edit: 7 months 3 weeks ago by
David Li.
