How do I set this up?
#2462
I'm pretty lost on how to control the IRUSB. I have the IR USB, I followed the instructions on VideoStorm's website to set up the device. I installed the VideoStorm driver in myServer. I went to driver config -> driver commands and clicked AddDevice. I entered the IP of my shield and added it. I clicked "Select Device" in driver commands and chose the ShieldIR I just set up. I went to SendIR- Nothing happens. Launch- Nothing happens. On my smartremote I see the IRUSB App. I clicked that, tried to send a remote command- nothing happens.
How do I set this up and control my shield with it? Didn't find any documentation, and the forum threads are pretty vague on how to actually set this up.
I have seen this thread and I think I've followed all of the instructions. allonis.com/forum/videostorm-irusb/244-videostorm-irusb?start=0
In IRUSB, I have Enable GC Protocol checked. In the Driver command testing window, none of the Send IR commands work because I can't choose any of my IR ports (smartremote is the one I want to test with).
E1: Looking at logging, when I run SelectDevice, I get this:
02/05/2024 00:48:43.48 · ERROR · IRUSB.doCommand - Error: No valid controller found for av|55~SelectDevice
E2: Now I don't even see my device anymore when clicking SelectDevice, so I guess I will uninstall and reinstall the driver for the 3rd time tonight.
Last edit: 2 years 6 months ago by zshaiken.
Re: How do I set this up?
#2465
allonis.com/support/documentation?view=category&id=429
Please add one forum post to the question.
#2477
I just read the support doc, and I was confused by this prerequisite:
AndroidTV integration already setup and in home assistant
Is home assistant required to use this device?
#2481
Not fully understanding your question.
HomeAssistant is not needed at all.
But, if you have a HomeAssistant system already, myServer can integrate to it for use with SmartRemote, myServer's more advanced user interface tools, additional drivers, etc.
There is a myServer IRUSB driver within native myServer so no need for HomeAssistant.
#2482
This is copied directly from the documentation you linked to.
Pre-requisites:
  • AndroidTV integration already setup and in home assistant
  • irUSB and companion app setup/installed on Nvidia Shield (should work on other ATV devices, but not tested)
Last edit: 2 years 6 months ago by cjisble. Reason: formatting
#2489
Pre-requisites:
Ah, got it.  That would be confusing.  Doc was updated to say "myServer" is the prerequisite.  No need for HomeAssistant for this feature. :)
