VM installs
VM installs
#3913
If there isn't already we should start a new thread just for VM based installations (with a big "Here be dragons" warning).
Last edit: 1 year 9 months ago by andrew.
#3916
OK I'm starting again, this time from Debian 12.9 ISO ( cdimage.debian.org/debian-cd/current/amd....9.0-amd64-DVD-1.iso ) with bare minimum installed initially (just SSH and system utilities i.e. no desktop). I'm installing under Proxmox 7.4-19 which is out of support already but I can't cope with installing and configuring another whole new thing at the moment...
The actual hardware is a Dell Optiplex USFF PC with an Intel Core i5-10500T CPU @ 2.30GHz, 16GB RAM and 1TB SSD.
VM specs:
CPU - 2 cores
Mem - 8GB
Disk - 150GB
I'll be following the official page here  allonis.com/support/documentation?view=category&id=416 except I shan't be installing anything Docker related unless I have to.
Last edit: 1 year 9 months ago by andrew. Reason: Guide link
#3918
Aren't the myserver drivers basically just docker containers ?
I see no other reason why docker would be essential for the installation.
But you have definitely looked at the how's and why's more than I have so I'm only guessing.
Last edit: 1 year 9 months ago by Fattykidd.
1 year 9 months ago
#3919
No, myServer drivers are not docker containers.
Some of the drivers leverage Allonis image docker containers to add optional software....but very few of those.
#3920
So docker is not essential to the installation of myserver ? And is actually "kind of optional" ?
If docker is not installed, will myServer give a warning or error if one tries to install one of those uncommon drivers that needs it ?
bitzerjd's Avatar
1 year 9 months ago
#3921
It's alive!  Debian 12.9 running under Virtualization Station on my QNAP.  The installation instructions were outdated and had a bunch of syntax issues.  No big deal, Professor Google helped a lot.    I will probably make this my backup server due to my current backup crashing at weird times.
