Macros
Re: Macros
#1145
Actually, in this instance you do not need to create any macros for the Sky Box. Rather you will install the CableTV driver. Add a new CableTV device. You set the devices IR Device and IR model and put the device into a room. When you save the server will automatically create the activation macro for you. I have new documentation for the CableTV driver going up on the website tomorrow that will document that entire process. If you can wait from the documentation to go up it will be a good test.
However, that does not eliminate the need for a good macros primer.
Is there something similar for a IR controlled Blu-Ray player?  Or do I need to write my own macro for it?
BlueRay IR Player driver is available in Software Updater
allonis.com/support/documentation?view=category&id=292
Re: Macros
#1147
I thought we're supposed to use the GenericIR driver? In the documentation you just linked it even says to download the GenericIR driver.
Re: Macros
#1149
Yes, you use both.  The GenericIR to get your hardware IR codecs in the myServer local database, and the BluRay Driver to map myServer AV commands to the IR commands.
Re: Macros
#1151
I updated my thread on the Panasonic UB-820 to explain what I did to setup the BluRayIR driver.
For the purpose of this thread, the activation macro was not created, nor was the source added.
Re: Macros
#1152
I've just tried with a Samsung BluRay player and Sky satellite box (pretending it's cable TV) and neither of them have created an activate-source macro.
Of course it's quite possible I'm not following the required steps exactly - I'm looking forward to the new CableTV driver documentation that should explain everything.
stanger89's Avatar
Re: Macros
#1154
So should it be something similar for an "AVR" that I setup Generic Serial commands for?
Actually I've got basically the same question for my DVR, which I found IR commands for but not "driver" per se.
Last edit: 2 years 7 months ago by stanger89.
Time to create page: 0.313 seconds
