myServer6 Macro Programming - Part 2
5 months 3 weeks ago
#4932
I created this macro, called toggleav, which is supposed to Toggle Power for the devices based on room (i.e. don't toggle AVR if in Living Room)
Macro|
If|isEQ##{{activeroom_name_smartremote1}}##Living Room##Macro|
AV|1~Power~Toggle!
AV|15~Power~Toggle!
SetVariable|testclient~WTF!
if|isEQ##{{activeroom_name_smartremote1}}##Theater##Macro|
AV|1~Power~Toggle!
AV|5~Power~Toggle!
AV|15~Power~Toggle!
SetVariable|testclient~{{activeroom_name_smartremote1}}!
// fini
When I run it from Living Room, it toggles everything as if the room is Theater, even though the active room is Living Room, and testclient = Living Room.  If I run it from Theater, it works properly.
Can anyone see anything wrong with this macro?
Thanks,
Mark
Re: myServer6 Macro Programming - Part 2
5 months 3 weeks ago - 5 months 3 weeks ago
#4933
Where are the devices AV1, AV5, and AV15 located? If those three are in the Theater room, why are you trying to control them while in the Living room?
If not, then what devices are in the living room and which ones are they?
Also review the syntax on IF statements. Yours doesn't look correct.
I thnk it should be:
Macro|
AV|1~Power~Toggle!
AV|15~Power~Toggle!
SetVariable|testclient~WTF!!
AV|1~Power~Toggle!
AV|5~Power~Toggle!
AV|15~Power~Toggle!
SetVariable|testclient~{{activeroom_name_smartremote1}}!!
// fini
Last edit: 5 months 3 weeks ago by aa6vh.
#4934
Living Room and Theater are the same room. Sometimes I like to watch TV just through the TV speakers (Living Room) and other times through the AVR (Theater).
Your syntax of the macro works. Thank you!
#4936
Have you discovered the Allonis "Live Event Log" yet? You access it from the dashboard, using the button at the bottom of the page. It will open a separate browser page. It is very helpful in debugging issues like this.
#4937
I have not. Thank you for the advice. I've gotten the remote to work my Living Room/Theater. I think I'm going to try to get Sonos working next.
Time to create page: 0.574 seconds
