Monoprice Monolith HTP-1 driver
davep's Avatar Topic Author
2 years 5 months ago
#2615
A driver for the Monoprice Monolith HTP-1 processor has been released. The driver currently supports the HTTP IR commands as described in the Monoprice manual. This is a one-way driver but should be workable until time and demand allows for development of a full two-driver.
There is no discovery. You must manually add the amp via command builder. The driver creates AV devices of type AVR. Let us know how/if it works.
Re: Monoprice Monolith HTP-1 driver
#2616
Everything except power commands appears to work from the command builder.
#2621
Their protocol document specifies that the discrete Power On and Power Off commands, while present, are disabled in the http irCmds. The Power Toggle should work. I left the discrete powers in there just in case they would work.
#2627
None of the 3 power commands work.
#2628
I did find a typo in the Power~On command and it has been fixed and published. Power~On, Power~Off and Power~Toggle all send the same IRCommand PowerToggle. Same as the Remote~PowerToggle command.
It's a shame they disabled them.
#2629
Will test later this evening.
I would assume they disabled the discrete commands you mention as it's not possible to interact with the unit when in low power mode.The power toggle command "should" only induce the standby mode which keeps the network portion of the htp online same as my ir commands.
