Driver Releases
Re: Driver Releases
#2082
I’ve already cleared the cache on my desktop.
I’m seeing the same thing on multiple devices.
Should I rebuild from the Master image?
I actually have a working USB backup which I could use but if it’s relatively simple to build from scratch I might do so.
Did you get to investigate the Storm driver?
Thanks.
Please read the prior post.  Your system is working fine.  No need to rebuild.
Check your IP addresss.
Storm will be looked at when there is time.
PhoenixF15E's Avatar
Re: Driver Releases
#2083
I've already sent my config.json to David quite a while ago.
In the meantime it's been working very well to just have the webui brought up on the remote screen.
I've also decided to use ezbeq instead of the built in beq functionality so I can blacklist a certain beq author. All of which is accessable from the smartremote screen.
Can you please post a copy of the config.json?  I'd like to take a look at one.
kirky27's Avatar
Re: Driver Releases
#2084
I read the post.
I have a question.
How do I verify the actual IP address?
Thanks.
Re: Driver Releases
#2085
I read the post.
I have a question.
Thanks.
"Or, ensure you are using the right IP address that might have changed on a reboot if you didn't reserve the IP address on your router DHCP server.
current IP is 20.10"
kirky27's Avatar
Re: Driver Releases
#2110
David,
A quick update. Turns out that I upgraded my network at home. Short story is that my VLAN permissions were incorrectly set and I could not communicate across VLANs. My IoT devices -of which the MyServer equipment is one is on an isolated network. Editing the rules fixed the problem.
Thank you for your help.
I'll move on to testing the updated Storm driver.
K.
Last edit: 2 years 6 months ago by kirky27.
Re: Driver Releases
#2111
David,
K.
That makes sense for the symptoms.  Glad you figured it out.
