CrabbyPatties's Avatar
This hasn't fixed the overrun issue.  Behaviour is exactly the same as prior.  I updated to latest drivers, latest template, updated project etc and no difference.  To made absolutely sure, I also checked it with the default smart-remote template and that also has the same behaviour.
my only option is to remote in and look at your log files to see if i can understand what it is doing.
#1541
I was going to send the logs over re the hard key overflow, but now I have a more serious problem.  The server will no longer connect to the Harmony Hub.  Is this due to the 'keep alive' issue that was changed recently?
 11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Reconnecting to Hub Hub at 192.168.68.56 at 192.168.68.5611/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Disposing11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Nulling11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Creating11/03/2024 17:23:48.23 · DEBUG · Harmony.ConnectAsync - Connecting to Hub Hub at 192.168.68.56 at 192.168.68.5611/03/2024 17:23:48.23 · ERROR · Harmony.ConnectAsync - Error in ConnectAsync - Unrecoverable stream error: resource-constraint11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Reconnecting to Hub Hub at 192.168.68.56 at 192.168.68.5611/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Closing11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Disposing11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Nulling11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Creating11/03/2024 17:23:48.23 · DEBUG · Harmony.ConnectAsync - Connecting to Hub Hub at 192.168.68.56 at 192.168.68.5611/03/2024 17:23:48.23 · ERROR · Harmony.ConnectAsync - Error in ConnectAsync - Unrecoverable stream error: resource-constraint
Last edit: 2 years 8 months ago by CrabbyPatties.
Please provide your TeamViewer info. Dave will need to log into the system directly to diagnose.
Thanx
David
Emailed it to you, thanks
your system isn't online to TeamViewer.
