CodZero's Avatar
Indeed. But it would've been easier if they'd just have included a proper POWER_ON command in the first place. Toggles are just annoying.
CrabbyPatties's Avatar
I still don't fancy building full power-on and power-off routines (with variables to track which devices turn on so they can later turn off) from scratch when I am at best an over-eager amateur. Would much rather use Harmony to activate activities and switch off again because it's easy...
But I still would very much like to have the option to start a Harmony activity without automatically being taken to the default Harmony scene....
David - can you solve this? Can you perhaps make a new command which starts a Harmony activity but without directing the remote to the default Harmony page?
Jim Peduto's Avatar
My Harmony implementation is working flawlessly.
I would like to program a few commands to the hard function buttons. Can you point mee in the right direction?
Give me an example of what you want to do and I will give some pointers
#1617
All Hard Buttons are configured in the myDesigner 6 application for either:
Default - at the webproject home page level global commands are set.
or, if there is a command on the current webpage there are button properties assigned there.  Button commands at the webpage level override the global commands.
That is the place to change the button behaviour.
Jim Peduto's Avatar
When watching TV:
Assign Previous Channel to F1.
Guide to F2
