Jim Peduto's Avatar
2 years 9 months ago
#924
thanks for the reply. Looks like we are stuck.
This is a lot more work and technical than I bargained for.
Know anyone that would like a hot deal on a remote and server?
#925
I wouldn't give up that easily. If it's a problem with the driver then I expect it would be easy enough for Allonis to sort out.
#926
I just released an update to the Harmony driver. The previous version would not try to reconnect to a hub if the hub disconnected. That's why restarting myServer made it come back. An big oversight on my part.
I also increased the discovery ping time out to 1500 milliseconds. This should make discovery more reliable on slower networks. Downside is that the discovery pass will take a bit longer to run.
Please update to the latest driver and see how that works. If there are any remaining issues I will have to remote into your systems to get more information.
#927
CrabbyP can you email me your myServer teamviewer ID. And could you also install TeamViewer on the pc where you are using the Designer? I want to see if I can see and resolve your issues. If you have previously sent this info to David kindly froward it to me. dave@allonis.com
#928
FattyK email me the teamviewer id of your server. I'll remote in and look. dave @ allonis.com.
Same holds true for anyone else. If I get inundated with requests I'll process in the order they come it.
#936
Updated the Harmony driver. Did a getConfig - it worked. Left it alone for half an hour. Did another getConfig - it worked straight away. So it looks like the disconnect problem is probably solved (I only say probably as my wife is watching TV so I can't test out actual remote control commands).
