Home Assistant driver installed and configured but no devices found
glc650's Avatar Topic Author
Re: Home Assistant driver installed and configured but no devices found
#705
Any update on this? HA support is a big reason why I purchased this remote so this remote isn't much use to me without it.
#1062
The HAGateway driver does not know how to talk to HA via SSL. I will update the driver to add this as an option.
#1077
I did a quick test on your system by modifying the driver so it would connect via https. It fails complaining about the invalid duckdns certificate. Chrome won't connect to it either. Will need to spend more time on this to find the solution.
#1078
The certificate is legit though.  It is from Let's Encrypt.  The myServer will either need to use Let's Encrypt's Root CA to connect or a way to ignore the cert and proceed with HTTPS anyway.
Last edit: 2 years 7 months ago by glc650.
