Home Assistant driver installed and configured but no devices found
Re: Home Assistant driver installed and configured but no devices found
Not sure what that is, but disable it and try again.
glc650's Avatar Topic Author
#636
It's required for my setup (Alexa and secure push notifications when away form home).
Does the HA driver use HTTP or HTTPS to connect to HA?
Last edit: 2 years 8 months ago by glc650.
I believe it talks http as there are no certificates setup or assumed.
Dave will have to chime in on details like what ports are used.  You might need to create an exception in your DNS / firewall software.
#641
There is no firewall involved.  My HA simply only listens on HTTPS/8123.  There is no way for me to change that and be able to use Alexa and secure pushes so I would need myServer to use HTTPS when talking to HA.  As for certs, Let's Encrypt is legit, non-self signed so myServer can either check to see if the FQDN in the URL matches the cert or just ignore that check and proceed, I'm good either way.
#644
This is all the log shows regarding this issue:
11/02/2024 16:30:54.30 · DEBUG · Server.WebCmd - Refreshgrids 11/02/2024 16:30:54.30 · ERROR · HAGateway.CreateClient - Error in MoveNext - Unable to connect to the remote server 11/02/2024 16:30:54.30 · ERROR · HAGateway.PopulateDevices - Error creating client for HA Controller at 10.1.0.8
Sounds like you are narrowing in on a connectivity issue.  Dave will advise re: http vs https.
