New setup, cannot create new projects but connected to myserver6
Re: New setup, cannot create new projects but connected to myserver6
I'm wondering if I found all the steps to follow. Things are sorta working, here's where I'm at:
  • Got MyServer setup/activated.
  • Went through and added all the drivers that exist so far
  • I setup rooms
  • Configured those drivers (notably for my initial setup, my Rokus and LG TV)
  • I think I've got those devices correctly assigned to the right room.
  • I setup the SmartRemote wifi, and connected to the server
    • Note that I initially screwed this up, but I went into the app settings in the Android settings and deleted the data and re-set it up.
  • I've got myDesigner connected to my server, and renamed the smartremote template.
  • I picked the right room on the SmartRemote and I see the correct devices* on the remote.
I think I'll start another thread with where I'm at though so as not to drag this off topic.
Quick look, that sounds pretty good!
stocks109's Avatar
I'm running into an issue where when I go to Create a New Project I'm getting a message that says
"Error at CreateNewProject at line #560 at column #7 - The user name or password is incorrect."
Obviously, some sort of validation error but I don't where to look to put in the correct info
#386
Email me your Teamviewer ID would be good to see how you are getting that message.  info@allonis.com
stocks109's Avatar
#387
Ok, will do.
Last edit: 2 years 8 months ago by stocks109.
Ok, will do.
You have the TV ID typed right?
#389
Right-click on the Windows Start Icon.   Select run.
In the Open dropdown type  \\A.B.C.D\myServer and click ok.
Where A.B.C.D equals the IP Address of your myServer device. e.g. \\192.168.0.23\myServer
Does it prompt you for credentials? If yes the username / password combination is allonis / allonis
Make sure to check off the "remember" checkbox.
Close and reopen the designer.
Was that the issue? Did that solve the problem?
Time to create page: 0.294 seconds
