Rackmount myServer - whole server unresponsive
bitzerjd's Avatar
Re: Rackmount myServer - whole server unresponsive
#3906
myServer-linux-x64
The only links that worked were the "Master Image" links. If you are updating the packages, it makes sense why they were not working.
Update - Just checked and it now worked!  Thanks
Last edit: 1 year 9 months ago by bitzerjd.
1 year 9 months ago
#3907
Try it now.
#3909
Thanks Andrew. Now that I've finally gotten my VM networking issues sorted on my rhel based server I can start up a Debbie VM and play around. Think I'll try it with and without desktop, I'm pretty sure Chris above is using it successfully without DE.
Last edit: 1 year 9 months ago by Fattykidd.
#3911
Yes.  Not sure it matters, but I am also using Ubuntu.  I started from:  ubuntu-22.04.3-live-server-amd64.iso
Last edit: 1 year 9 months ago by cjisble.
1 year 9 months ago
#3912
Oh, well since I haven't started configuring it yet maybe I'll burn it down and start from minimal server instead. Thanks - the less stuff that's running on a server the happier I am.
1 year 9 months ago
#3914
Any reason you're using 22.04 instead of 24.04 or did you do a dist-upgrade after standing it up ?
Mostly the same packages but I think the Ubuntu repo has more ?? Than the debian repo. Definitely more up to date packages in the Ubuntu repo.
Time to create page: 0.095 seconds
