ADB Segmentation fault
Mark Stocku's Avatar Topic Author
Re: ADB Segmentation fault
1 year 6 months ago
#4200
Thanks David.  Downloading the new image now.  FYI I did go through the exact steps and used BalenaEtcher for OSX onto a USB drive with the previous image and  I booted the Pi5 onto the USB drive and did not update anything and still got the segmentation fault when accessing adb.  So for kicks, I then booted up on the nvme drive on a fresh base pi5 OS and then installed the android adb package and it worked.  Hopefully this new image fixes that.
#4201
The new image still gives me the segmentation fault on adb commands.
I first created a bootable usb on my MBP following the instructions.  I booted the Pi up on the usb went through the restarts.  Only thing I did was then check adb via command line.  Fault.
Decided to try creating the boot usb from a windows 11 pro pc as maybe this was something with OSX. I downloaded a new zip image, I  Followed the steps, used belaEtcher (running as admin) created the boot USB.  Plugged it into the Pi andLet it go through its reboots.  I did not update software or OS.  It gives me the segmentation fault when I try any adb command in terminal.  This fault has to be in the image file,  only unless the image has some major issue with my pi5.
Thanks,
--Mark
Last edit: 1 year 6 months ago by Mark Stocku.
1 year 6 months ago
#4202
email me your PI's teamviewer ID. I need to remote in and look at what's going on.  (dave at allonis.com)
1 year 6 months ago
#4203
thanks Dave, I sent the id to connect to you.  I appreciate it.
1 year 6 months ago
#4204
Fixed, somehow I managed to get the x86 version of ADB loaded onto our arm64 master image. Egg on my face....
The following user(s) said Thank You: Mark Stocku
1 year 6 months ago
#4205
LOL it happens.  Thanks so much for troubleshooting and figuring it out. It sure does work now!  Now back to getting this all setup, glad you could get it fixed.
Thanks!
Time to create page: 0.556 seconds
