ADB Segmentation fault
Mark Stocku's Avatar Topic Author
Re: ADB Segmentation fault
1 year 6 months ago
#4194
Great, thanks.  I'll try to image the USB drive vs the micro sd card.  I do have an 1tb nvme drive on the Pi that i will image with the usb image.
1 year 6 months ago
#4195
The Master Image will very soon be updated...
1 year 6 months ago
#4196
Thanks David, I guess I better hang tight then.  While I'm going through the steps now, as outlined in the documentation using a usb drive this time.  I'll use the new one once it is updated.
Thanks Again!
1 year 6 months ago
#4197
Image is being uploaded now. Make sure you follow all documentation step by step. Critical for success. Also, the license that gets applied is for the hardware it is installed to / for. There is a fee for Allonis to move the license so make sure you are making long term decisions on what you are installing to.
The following user(s) said Thank You: Mark Stocku
1 year 6 months ago
#4198
Excellent, thank you David.  I'll use that new image.  To clarify, when you say the license that gets applied is the purchased license, not the30 day trial that it comes with?  So when I do get this all setup in trial mode, once I do purchase the server license it will be applied to the hardware at that time?  Meaning its not applied to the trial license on install/image?
Thanks,
--Mark
1 year 6 months ago
#4199
Image should be there now.
support / documentation / downloads
