ADB Segmentation fault
Mark Stocku's Avatar Topic Author
Re: ADB Segmentation fault
1 year 5 months ago - 1 year 5 months ago
#4212
I'm still having issues with adding a fire tv as a device..  I'm not sure if the issue is related to the image this time because it seems to be just with MyServer. ADB is working on the Pi server. ADB Debug is on on the Fire TV stick.  I can connect to the the FireTV using the adb command on the terminal from the pi server and it will show up in the devices if I do a terminal command of adb devices. In myserver I can't add a device, none are discoverable, nothing shows up in the list.
When I try to manually AddDevice command in the driver manager for the andriodtv driver, it returns a "Error in MoveNext The input string [depends on what string used] was not in a correct format" In system events. I've deleted the use of that single variable it errors,(for example friendlyname)  but then errors on another value (for example Room Name) in the string. is this a related issue to the image or is it something I'm missing in the documentation?  Thanks!
Last edit: 1 year 5 months ago by Mark Stocku.
1 year 5 months ago
#4217
We were able to manually add a few devices we manually located on your network.
Need to look deeper on why Discovery wasn't working on your network.
Also, I assume you didn't have all fields selected when running the AddDevice command as it seems there were missing parameters that offset required fields from getting populated.
1 year 5 months ago
#4218
Thanks David. User error on my part. I was at least skipping the parameters for the signage when i was creating the command string. Thanks!
1 year 5 months ago
#4225
Update to close this out.  Both FireTV's are now working.  Thanks for the help, Dave's.
Time to create page: 0.455 seconds
