ADB Segmentation fault
Mark Stocku's Avatar Topic Author
1 year 7 months ago
#4186
I'm having an Android TV Driver issue adding devices.  David had directed me to do a command line 'ADB Devices' command to check if the IP is connected.  However the issue is any ADB command i do returns a "Segmentation Fault" error response.
Re: ADB Segmentation fault
1 year 7 months ago - 1 year 7 months ago
#4187
Some more information.  This is running on a RaspberryPI 5 using the downloadedPI5-4-Master arm65 image. Image was created using the Raspberry PI Imager for OSX to an sdxc card and then imaged to the NVME drive on the pi5 using the pi's imager.  PI server os is up to date and the allonis myserver is at 6.8.236.34236
Last edit: 1 year 7 months ago by Mark Stocku.
1 year 7 months ago
#4188
That error may be related to a storage drive fragmentation issue ie: corruption.
Not positive.
The following user(s) said Thank You: Mark Stocku
1 year 7 months ago
#4190
Thanks David.  After a few attempts at trying to reinstall I've decided to nuke it and try again.  First though I'm going to see if I get the error on the sdxc image first.  I'm wondering if I should format a usb drive with the image and image over to the drive vs using the sdxc boot image.  Thanks!
1 year 7 months ago
#4192
actually its getting the error while booted up on  the sd card image.  I guess I need to really start back from scratch.  Thanks again.
1 year 7 months ago
#4193
Recommended is not to use an SD card....Use a fast 400mhz USB drive. Or a M.2 storage drive (even faster / better).
SDMicro are not very durable / reliable.
