Sprinkler Relay Questions
Chrisan's Avatar Topic Author
1 year 8 months ago
#4084
Couple questions.
Looks like this guy hooks up with a wired LAN connection, correct?
I'm going to need more than one of these  as I'll probably be running 10 zones or so.   Do I somehow daisy chain them or do I run 2 LAN cables?   Would the Sprinkler App integrate seamlessly with such a setup?
Thanks!  Chris
Will Riker's Avatar
Re: Sprinkler Relay Questions
1 year 8 months ago
#4085
Looks like Sainsmart has discontinued their IP controlled relays however this looks exactly like the generic ones that you can find on Amazon or Alibaba.  They probably all use the same protocol.  You can't daisy chain them
1 year 8 months ago
#4088
what "guy"?
We have been thru a lot of relays. We sell the ones that we see work best. I wouldn't guess as protocols are not consistent. There needs to be a driver specific to the relay you want to use. The Irrigation app runs macros. The relays to trigger is managed by the relay driver.
#4089
"What guy?"
I thought this was the SainSmart IP relay section, no?   :)   So the SainSmarts are connected via a Lan cable correct?    And you can't daisy chain them so I'll need a separate Lan cable if I use two units?    And the App can map to the relays in such a way when it's time to run, say,  zone 9 it would know SainSmart unit 2, relay #4 of that unit is the one to be activated?   This is way different that a Rain8, just trying to picture how it would work.
Thx
Last edit: 1 year 8 months ago by Chrisan.
1 year 8 months ago
#4092
Yes, IP relays (like most from SainSmart) require an ethernet cable to a network switch, OR a Wifi connection (ethernet is recommended for reliability). Each relay board gets an IP address. Each relay on the board is individually controllable.
1 year 8 months ago
#4093
Ah, thanks, good info. Irrigation will be a spring project for me soon. Have to get lighting and HVAC going first!
