#1994
Try removing ipv6 networking.  See myserver startup documentation.  Bottom of doc
Sounds like a network issue
CrabbyPatties's Avatar
#2024
Thanks David. I’ve checked - my router has ipv6 disabled.
#2026
Please reread the docs to disable IPV6 on the myServer controller (not just the router)
#2034
I've reread the docs and now disabled ipv6 on the pi for ethernet connection (from networking settings on the taskbar). Will let you know if it makes a difference. If it is not required, perhaps it should be off by default?
#2038
yup, it is very likely that ipv6 will be disabled by default in the next Master Image.  Hopefully that helps your situation.
#2088
I'm afraid it hasn't.  Hub has fallen off again.  Not responding to any commands.
Time to create page: 0.114 seconds
